TI Process with Cube and View Name as Parameter
raeldor
- OLAP Product: IBM PAW
- Version: Unknown
- Excel Version: 365
Is it possible to pass the view and cube name as a parameter of the TI Process for a more 'generic' export process? Can I pick the data source in the Prolog instead? Thanks.
- Steve Rowe
Re: TI Process with Cube and View Name as Parameter
You need to read up on TI Local Variables https://www.ibm.com/docs/sl/planning-an ... -variables
Specifically in this case DatasourceNameForServer and DatasourceCubeview
raeldor
- Version: Unknown
This looks like just what I'm looking for. I'll give it a try... thank you!Steve Rowe wrote: ↑Fri Apr 19, 2024 8:31 am You need to read up on TI Local Variables https://www.ibm.com/docs/sl/planning-an ... -variables
hmmm ... a generic process for exporting TM1 cube data you say ...
https://github.com/cubewise-code/bedroc ... export.pro
ardi
- OLAP Product: tm1, cognos bi
- Version: from TM1 9.4 to PA 2.0.9.6
Yes you can, you can create the View in a master process and pass the name of the view to the other export process along with name of View
But if you have TM1Py, MDXPy, they will generate the extract much faster than the AsciiOutput for each row in the Data tab
Ardian Alikaj
konstantin-spb
- Version: PA 2.0.9
Yes you can do it.
See bedrock for an example or use bedrock right away.
https://code.cubewise.com/open-source/bedrock/
