Conditional Pick Lists
KaneHenderson
Version: 2.0.9.11
Excel Version: 16
Post by KaneHenderson »
I was wondering if it is feasible to have a dynamic picklist selection based on another picklist cell.
For example, if we have a picklist that has x / y / z and another picklist containing a / b / c / d / e. I'm looking to form a relationship between the two as follows:
IF Picklist 1 is X then picklist 2 would have a / b
IF Picklist 1 is Y then picklist 2 would have c and
IF Picklist 1 is Z then d / e
I'm trying to do this to avoid incorrect data mappings, rather than having Picklist 2 having a / b / c / d / e.
Thanks in advance for any support!
Re: Conditional Pick Lists
Hello
Did you try Google on:
TM1 dependent picklists
KaneHenderson
Version: 2.0.9.11
Excel Version: 16
Hi Wim,
Thank you for this. It really helped me to understand more about using picklist control cubes.
I've wrote this rule for one of my picklists:
['Tableau Sub-Function Level 1']=S:IF(DB('74 MDM Tableau - Entity and Cost Centre W Locations',!070 MDM - Tableau Reporting Log List,'Tableau Function')@='EXECUTIVE','subset: 018 Main - Sub-Functions: EXECUTIVE Function',
IF(DB('74 MDM Tableau - Entity and Cost Centre W Locations',!070 MDM - Tableau Reporting Log List,'Tableau Function')@='FACILITIES','subset: 018 Main - Sub-Functions: FACILITIES Function',
IF(DB('74 MDM Tableau - Entity and Cost Centre W Locations',!070 MDM - Tableau Reporting Log List,'Tableau Function')@='FINANCE','subset: 018 Main - Sub-Functions: FINANCE Function',CONTINUE)));
It quite bizarrely works for some lines in my log, but not others. For example:
Where Tableau Function is EXECUTIVE, the picklist populates on line 10 of my log
Where Tableau Function is EXECUTIVE, the picklist doesn't populate and remains as a string data entry value, almost as if the rule doesn't hit the cell.
KaneHenderson wrote: ↑Fri Mar 08, 2024 2:51 pm Hi Wim,
Hello
Please make sure that all subsets exist, as public subsets in the respective dimensions.
They can be static or dynamic, doesn’t matter.
It’s a bit odd that sometimes you use no spaces, sometimes you use 2 spaces in front of a dash, …
I don’t put a space after the colon in the picklist definition but probably it will work too with a space.
