[Urgent]Cannot display all available attributes in TM1 Web
Posted: Mon Oct 19, 2009 8:06 am
by kempzhong
Dear all,
I encountered with a problem when filtering elements by attributes on TM1 Web. There are more than 200 elements in product dimension. Each element has its own attribute. When I use Perspective to filter (Select all -> filter by attribute), there is no problem. Please find the snap below:
- perspective.GIF (30.71 KiB) Viewed 6884 times
However, when I use TM1 Web for filtering, it cannot display all attributes for selection. The last three attributes are missing.
- TM1Web.GIF (27.47 KiB) Viewed 6883 times
Has anybody have such problem before? It seems it's a bug of TM1 web....Anybody can help? Many Thanks
Re: [Urgent]Cannot display all available attributes in TM1 Web
Posted: Mon Oct 19, 2009 11:13 am
by jonathan.d
What version of tm1 are you running? And, have you applied any of the hot fixes?
Posted: Mon Oct 19, 2009 11:20 am
by Martin Ryan
The asterisk in the top bar of your subset in the second picture indicates that you have made some changes to the subset since you opened it. It is possible that you've merely filtered some of the elements out already including the ones you want.
The drop down list only shows you attributes for elements that are currently in the subset editor.
Try reloading the default subset and trying again.
Martin
Posted: Mon Oct 19, 2009 1:25 pm
by kempzhong
Martin Ryan wrote:The asterisk in the top bar of your subset in the second picture indicates that you have made some changes to the subset since you opened it. It is possible that you've merely filtered some of the elements out already including the ones you want.
Martin
Martin, thanks for your reply
But I did the filtering action in TM1 Web as this order: Select all -> Filter by attributes. When I select all, elements cannot be displayed in 1 page in the subset editor. Is that means I only can filter the elements by attributes in the current page? However, I tried to go to page 2 and filter, but no luck. The last 3 attributes are still missing...I am very confused....
Posted: Mon Oct 19, 2009 9:42 pm
Why do you have a unique attribute for each and every dimension member? This is a very odd piece of design! Why would this be necessary?
Posted: Tue Oct 20, 2009 1:21 am
by kempzhong
lotsaram wrote:Why do you have a unique attribute for each and every dimension member? This is a very odd piece of design! Why would this be necessary?
We don't want to do that indeed. But our client insists to do so....Anyway, it should display every thing normally in my understanding in TM1 Web.
Posted: Thu Jul 22, 2010 11:08 am
by Ajay
Did you find an answer to this ?
I have a similar issue, in that I can utlise the functionality in perspectives but can't see any of them in web. I even restarted the web server just to make sure.
Please see screen shot below.
- Web_SelectbyAttribute.JPG (61.02 KiB) Viewed 6725 times
I am using Web for 9.0 SP3 U7
Let me know if you need any addditional info
Ajay
