Flexible PickList Definitions
schlemiel29
OLAP Product: TM/1
Version: 11.8
Excel Version: Excel 365
Post by schlemiel29 »
I want to have a Picklist for all used user defined dimensions. So I want a complete list of all elements, which would be:
Dimension:DimName
I also want to offer a list of all elements without the top level and a list without the leaf elements.
Additionally I need to show attribute names defined in every dimension.
So I would define a subset, based on an MDX, which filters the levels and then fix it as a static subset. This named subset I can use later in my Picklist cube.
BUT: I have so many dimensions, for each I have to do exactly the same selections. Is there an easier way to do this, like using a kind of MDX in a rule which feeds the Picklist cube?
Thanks in advance
Dirk
ardi
OLAP Product: tm1, cognos bi
Re: Flexible PickList Definitions
Post by ardi »
schlemiel29 wrote: Wed Dec 13, 2023 2:12 pm Hi,
Dimension:DimName
Thanks in advance
Dirk
You should use Subset Picklist instead of Dimension Picklist
Ardian Alikaj
This was touched on in some other threads recently.
You can only point the picklist at a dimension, set or static list. Therefore if you have a complex need delivered by MDX then you must create a public set to deliver the list. You can not point a picklist directly at a MDX statement.
If you have a standard set of MDX sets you want in play against all your dimensions then you should be using a TI to loop over the dimensions and the MDX definitions to build the sets.
