PAW - GIT Repository Connection issue
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
We are trying to use the new PAW feature to add TM1 objects to GIT Repository, and for some reason, we cannot make it work.
We have generated the SSH Public Key / Private Key, and also saved the SSH Key to GitHub, but when we enter the Repo URL / SSH Keys in PAW, we receive an error:
TM1 Git failed to connect to remote. Reason: Failed to authenticate SSH session: Callback returned error.
Not sure if anyone else has experienced this error
Thank you
Ardian Alikaj
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: PAW - GIT Repository Connection issue
Post by ascheevel »
Public or enterprise Github? I ran into similar errors trying to connect on-prem PAW to an enterprise Github repo and so far haven't got it working. I suspected that the connection was being blocked/rejected by enterprise github admins but haven't confirmed that. You are using the SSH url and not the http url?
ardi
Post by ardi »
ascheevel wrote: Tue Dec 12, 2023 4:32 pm Public or enterprise Github? I ran into similar errors trying to connect on-prem PAW to an enterprise Github repo and so far haven't got it working. I suspected that the connection was being blocked/rejected by enterprise github admins but haven't confirmed that. You are using the SSH url and not the http url?
I am connecting to a Private Enterprise GitHub also, and my PAW is on-prem (2.0.86), so I think I am on the same situation. I am also using the SSH URL ( git@....)
Thank you for sharing
Ardian Alikaj
WilliamSmith
OLAP Product: TM1 / PA / PAx / PAW
Version: TM1 11
Excel Version: 365
Post by WilliamSmith »
+1 tried to get this working today, but no avail, will keep plugging away at it and report back any success
ZLD
Version: 2.0.9.18
Post by ZLD »
What SSH algorithm did you use to generate SSH key? If it was Ed25519, you may want to try RSA (ssh-keygen -t rsa -b 4096 -C "your_email@example.com"). Older TM1 does not support Ed25519 to authenticate to git repository.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Tried both, I get the RSA with SHA-1 no longer supported by github error.
ZLD
Version: 2.0.9.18
Post by ZLD »
Can you try "ssh-keygen -t rsa -b 4096 -C "your_email@example.com'" to generate the RSA 4096? It is supported by GitHub https://docs.github.com/en/authenticati ... -ssh-agent.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Yep, that's what I tried using the same github documentation you linked. I can see when I add the key in Github that's it's labeled as a SHA256 key, but same error when trying to connect from TM1.
Thanks for suggestion, hopefully it works for anyone else stumbling onto this. For me, I've all but given up on IBM's flavor of GIT integration for TM1 and am designing my own github based source control and deployment pipeline.
wcoffen
OLAP Product: PA/TM1
Version: 2.0.9.17
Excel Version: 365
Post by wcoffen »
Try $ ssh-keygen -t ecdsa -C "youremail@address"
I had an issue with a different algorithm for PA Cloud and IBM suggested "ecdsa" and it worked.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
Well....that worked. Thanks @wcoffen!
