Hello All
[Unable to fetch data. "Label" : member not found (rte 81)]
Was wondering if anyone sees this error when moving between versions and if there is a possible solution?
Thank you in advanced.
PAW reports error
- OLAP Product: cognos
- gtonkin
Re: PAW reports error
Looks like something failing in the underlying MDX based on that error.
You may want to try open the board specification (Ctrl + / + q) then copy and paste into notepad and do a search to see where Label may be used.
So when i do look at the mdx, I dont see any issues, strangely throws a error intermittently, seems like an intermittent fault on the period dimension, not always. just feels like a weird behaviour.
