Export }-Cubes with Bedrock
schlemiel29
OLAP Product: TM/1
Version: 11.8
Excel Version: Excel 365
Post by schlemiel29 »
I want to export a file with attribute data, meaning attribute name and type. So I though it would simply be an export of the cube
'}ElementAttributes_' + Dimensionname
When using '}bedrock.cube.data.export' with my own created cubes, it works fine. But when using an }-Cube nothing happens.I only changed the cube name, nothing else!
Any idea?
schlemiel29
OLAP Product: TM/1
Version: 11.8
Re: Export }-Cubes with Bedrock
Sorry, found a solution by myself. Instead of exporting the cube, I can export the dimension '}ElementAttributes_' + Dimensionname.
The process }bedrock.hier.export will include all attribute names and type in the header, before the body which contains the hierarchy structure and attribute values. So if you want the attribute values it will be in that file.
If you aren't interested in the structure you could always just ignore all rows starting with "E" and "P".
schlemiel29
OLAP Product: TM/1
Version: 11.8
Thanks, I will use it.
