Distinguish between default and other hierarchies
MarenC
Excel Version: Excel 2016
Post by MarenC »
Does anyone know if we can distinguish between the default hierarchy and other hierarchies using TM1 objects? In order to find all the other hierarchies in a model, for every dimension.
The only place I can see where this is possible is in the }dimensions dimension, the other hierarchies seem to use the colon as a separator to identify the hierarchy,
For example, a Country dimension will have Country as the default hierarchy and Country:Leaves as the leaf hierarchy, Country:West as the West countries etc etc.
But, an existing default dimension may already contain a colon, so finding the colon is not really an ideal option, unless you are strict with naming conventions. Ideally all of these other hierarchies would be in a dimension of their own.
So, is there another way to identify all of the other hierarchies in a tm1 model?
Maren
Re: Distinguish between default and other hierarchies
Is it possible to create a new dimension with a colon ? Not sure and not on my laptop to check.
MarenC
Post by MarenC »
Hi Wim,
No, it isn't! :oops:
Maren
It’s Monday for a reason :D
MarenC
Post by MarenC »
I was lulled in by the fact that they are using a colon in these dimension names, so I just assumed that the character was allowed.
That is my excuse, but maybe Monday is a better one!
