Mdx statement for zero suppression based on control cube
ahameed
- OLAP Product: Tm1
- Version: 11.8
- Excel Version: 2021
Hello, I have a Customers dimension and I would like to create a subset on it to show All elements if a value in a 2 dimension control cube is false and show only customers that have data in the Customers cube if the value in the control cube says true.
In the end I am trying to do zero suppression switch using a combination of a Pax websheet and a PAW view. The Zero suppression switch is in the Pax websheet that will suppress or unsuppress the customers in the PAW view.
I have tried many combinations of MDX based on the MDX reference that found here but cant seem to get it right. I know that I need to use IIF but can figure of the "then" part of statement.
This what I have so far
STRTOSET("[Customers].[Customers].[" + IIF([Client Selections].(STRTOMEMBER("[}Clients].[" + UserName + "]"),[MD_Selection].[Suppression Selection]) = "False" , " 9000000" , [Client Selections].(STRTOMEMBER("[}Clients].[" + UserName + "]"),[MD_Selection].[Header])) + "].children")
The 9000000 is a code for Total Customers and I am trying to get all level 0 customers with that.
Also, if I am overcomplicating things and just might be, kindly suggest a better why to achieve what I am trying to do. Thank you in advance for your time.
ardi
- OLAP Product: tm1, cognos bi
- Version: from TM1 9.4 to PA 2.0.9.6
Re: Mdx statement for zero suppression based on control cube
Try something like this:
{FILTER ( {TM1SUBSETALL( [Customer_Dim] )} , [zControlCube].([ControlElements].[Zero Suppression Flag],[zControlCube_m].[Value])=0 OR ( [zControlCube].([ControlElements].[Zero Suppression Flag],[zControlCube_m].[Value])= 1 AND [CustomerCube].([Dim1].[Total_Elem], [Dim2].[Total_Elem], [CustomerCube_m].[Amount]) <> 0 ) )}Ardian Alikaj
ahameed
- OLAP Product: Tm1
- Version: 11.8
Thanks for response @ardi. I appreciate it. Does it matter if the suppression flag is string. Like a True or False ?
Yes. If it is string you would compare with ="1"
ahameed
- OLAP Product: Tm1
- Version: 11.8
Thank you Wim.
I have this so far and the suppression filter is not working. Its probably the Or/And combo but I cant pin point it. When I select False in the Client Selections cube I do not get all the level zero elements.
FILTER(TM1FILTERBYLEVEL(TM1SUBSETALL([Customers]) , 0) ,
[Client Selections].(STRTOMEMBER("[}Clients].[" + USERNAME + "]"),[MD_Selection].[Suppression Selection]) = "False"
OR [Client Selections].(STRTOMEMBER("[}Clients].[" + USERNAME + "]"),[MD_Selection].[Suppression Selection]) = "True"
AND
[Customer Summary].([Organizations].CurrentMember,[Periods].CurrentMember,[Regions].[99999],[Currency].[USD],[Customer Sources].[Total],[Versions].[Actual],[Customer Summary Measures].[SRP-Month-Sales]) >0)
AND
ardi
You need to use round brackets after the OR operator
Ardian Alikaj
ardi
Try the following:
OR
([Client Selections].(STRTOMEMBER("[}Clients].[" + USERNAME + "]"),[MD_Selection].[Suppression Selection]) = "True"
AND
[Customer Summary].([Organizations].CurrentMember,[Periods].CurrentMember,[Regions].[99999],[Currency].[USD],[Customer Sources].[Total],[Versions].[Actual],[Customer Summary Measures].[SRP-Month-Sales]) >0 ) )
OR
AND
Ardian Alikaj
ahameed
- OLAP Product: Tm1
- Version: 11.8
That worked beautifully. Thanks for pointing out the fact that I failed to encapsulate the second clause. Thank you Ardian. Much appreciated.
ahameed
- OLAP Product: Tm1
- Version: 11.8
One last question and I promise this would be it. I think
Is there a way concatenate YTD to the [Periods].CurrentMember.
I tried [Periods].CurrentMember + ("YTD") but not resolving
Try the StrToMember() syntax with inside that [Periods].CurrentMember.Properties(“Name”) + “YTD” bit.
ahameed
- OLAP Product: Tm1
- Version: 11.8
Hey guys, I am back with more problems
. I cant get that currentmember to resolve let alone add YTD to it. Any ideas on this one ?
FILTER(
TM1FILTERBYLEVEL(TM1SUBSETALL([Customers]), 0),
) = "False"
OR
) = "True"
AND
[Organizations].CURRENTMEMBER,
STRTOMEMBER("[PERIODS].["+ [Periods].CURRENTMEMBER.Properties("PeriodName") + "]"),
[Regions].[99999],
[Currency].[USD],
[Customer Summary Measures].[SRP-YTD-Sales]
) > 0
FILTER(
) = "False"
OR
) = "True"
AND
[Regions].[99999],
[Currency].[USD],
) > 0
ahameed
- OLAP Product: Tm1
- Version: 11.8
Hi guys, I finally had the time to get back to this and getting close I think
I have come up with this but not getting any elements. Can someone point out what's wrong with my syntax. Thank you
STRTOMEMBER("[Periods].[" + [Periods].CURRENTMEMBER.NAME + " YTD]"),
FILTER(
) = "False"
OR
) = "True"
AND
[Regions].[99999],
[Currency].[USD],
) > 0
FILTER(
) = "False"
OR
) = "True"
AND
[Regions].[99999],
[Currency].[USD],
) > 0
MarenC
- Excel Version: Excel 2016
I think an alternative to this:
Maren
would be to reference a lookup cube for the current period, so something along the lines of:STRTOMEMBER("[Periods].[" + [Periods].CURRENTMEMBER.NAME + " YTD]")
StrToMember("[Periods].[" + [Lookup Cube].([Lookup Line].[Current Period],[Lookup Measure].[String] +" YTD]")-
ahameed
- OLAP Product: Tm1
- Version: 11.8
Great idea @Marenc. That worked. Thank you so much.
