TM1 print report wizard
Posted: Tue Jul 18, 2023 7:19 am
Hi everyone (wave)
I have a question regarding the print report wizard in TM1. I have several reports that users would like to print as a PDF. I discovered the print report wizard, but it somehow does not work the way I believe it should.
I want to print a specific sheet (which works) for a specific title dimension (which also works) as a PDF. If I select 'print single workbook' it works fine, but I want to have a seperate PDF for every element in my title dimension. The way to do that should be to select 'print multiple workbooks' and check the box 'Create a new workbook for each title', but when I then try to generate the PDFs I always get an error stating: 'was not installed correctly.'
Unfortunately, I can't do much with this error message, as the PDF print itself works, so I don't know what is missing (not installed).
Any help is appreciated, thanks!
Thomas
Thomas
