Calculate Average in Rules
ajain86
Version: 9.4.1 9.5 9.5.1
Excel Version: 2003 2007
Post by ajain86 »
I need to calculate an average of multiple cells and assign that to another cell using cube rules.
The reason I cannot simply do an add and divide is because I need it to ignore cells with 0.
Ex:
Prices-
A = 10
B = 20
C = 30
D = 0
If I do a sum and divide, it is 60 / 4 = 15. What I need is 60 / 3 = 20.
I have found some references to using AVG which is an MDX function but I have not found any references to see how it would be implemented in TM1.
Any ideas?
Ankur Jain
Martin Ryan
Re: Calculate Average in Rules
Post by Martin Ryan »
There are a couple of suggestions for handling averages here: http://forums.olapforums.com/viewtopic.php?f=21&t=388
ajain86
Post by ajain86 »
Martin,
I read through that post. I wish there was just like an AVG or average function that would do this without me having to create a new member or rollups as my current rule is pretty complex and adding a new element would just make it longer and more complex.
Ankur Jain
chrisTM1
Version: 9.4
Post by chrisTM1 »
Well,
A solution is to create two new columns. One will hold the initial value. The other One is a counter.
In the Rule:
You move value A to Hold_A, B to Hold_B etc.
Then Conditional Statement: When Hold_A different from 0 then Counter_A=1 otherwise 0.
Average calculation= For the consildation Only Divide Roll up Hold values by Counter then u get ur average as wished...
Hope it helps...
Description:
A=10 Hold_A=10 Counter_A=1
B=20 Hold_B=20 Counter_B=1
C=30 Hold_C=30 Counter_C=1
D=0 Hold_D=0 Counter_D=0
TotalABCD=60 TotalHold_Values=60 Total_Counter=3
Average Calculation=TotalHold_Values=60 \ Total_Counter=3 =60/3
C>
ajain86
Post by ajain86 »
Chris,
I looked into this, but due to the complexity of the cube, I was unable to do this. I had to create a work around solution.
Average = (A + B + C + D) / (A\A + B\B + C\C +D\D) .
This provides the correct answer but is a big mess to look at in the rules as member names are quite long.
Ankur Jain
