Limiting drop down values by user using MDX
Posted: Thu Jun 29, 2023 6:54 pm
I am wondering if it is possible and if so how you could use MDX to limit the values returned in a drop down by the user logged in.
User opens a TM1Web data entry form and has to enter data for 4 companies they are responsible for. Currently when they select the drop down they see all the companies in the system.
Is there a way to use MDX so that they would only see the companies that they are aligned to. We align the user to the companies in a cube and then push the security using a process to assign with read or write access to the companies.
Any insight would be appreciated
