Hi TM1ers,
I need to add status displaying the start and the end of a TI process.
I know that TI processes don't commit its data until the end of the process.
So I opted of another solution. I created a parent process, where I added a cellputS to my new logging cube( with status ' Running'). Then I called my original process using RunProcess.
Somehow, the cellputS didnt work even though both processes need to run in parallele. Any idea why ?
I switched now to using attributes, and it worked for me. The 'Running' status is added at the start.
I am writting this process so I can understand why CellputS didnt work but the attribute insertion worked?
Also, I would love if there is any better solution to go with ?
Insert Progress status in TI process
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Insert Progress status in TI process
Hi, below discussion might help. try to use asynchronous function, which CellputS is not actually.
https://www.tm1forum.com/viewtopic.php?t=14850 Thank you.
- qml
- Excel Version: 2007 - 2016
If your status cube is small (which it typically is) then one way to commit value changes done via CellPutN/CellPutS in it right away is to invoke CubeSaveData() on that cube, which commits data mid-process and serialises the cube to disk.
Normally data is committed only at the end of the transaction i.e. at the end of the parent process.
Kamil Arendt
