For Modelers and Analysts:
- Conduct a quick audit of a new or legacy model and build a visual lineage between cubes and other system elements;
- Find potential problem areas and bottlenecks among model objects;
- Quickly retrieve data that may not be very convenient to obtain using standard IBM Planning Analytics (Cognos TM1) tools, for example: which cubes use one or another dimension, cubes sparsity, etc.;
- Get quick visual information about security settings (for example, who has access to the selected cube and access level, or, conversely, which cubes the selected user has access to);
- Identify the top cubes with the longest recalculation time (re-feed);
- Receive visualized information about the size of cubes and their components, as well as changes in the amount of memory used over time.
- Monitor data about user activity during the working day on the dashboard;
- Get a list of inactive accounts in order to optimize user licenses;
- Get a visual representation of the model functional map;
- 2. Evaluate source data necessary to generate the final reports of the model;
- Search for changes in the Model by the new values and view data change in the transaction log using suitable aliases using;
- Determine the Processes that change the data in the target cubes;
