PAfE VBA Refresh in Manual Calc Mode
WilliamSmith
OLAP Product: TM1 / PA / PAx / PAW
Version: TM1 11
Excel Version: 365
Post by WilliamSmith »
Sharing findings I discovered today. We've been wracking our brains trying to find a way to get PAfE to refresh DBRWs etc. while staying in manual calc mode. The .Dirty() method of the Range class seems to be the magic function.
Anyone have a better way to do this?
Sub RecalcSelection()
    Application.EnableEvents = False
    Application.Calculation = xlCalculationAutomatic
    Application.EnableEvents = True
    Selection.Dirty
    Application.Calculation = xlManual
End Sub
Sub RecalcSheet()
    Dim ws As Worksheet
    Set ws = ActiveSheet
    ws.Cells.Dirty
End Sub
sebsimpson
Version: 2.0.9.16
Excel Version: O365
Re: PAfE VBA Refresh in Manual Calc Mode
Post by sebsimpson »
I investigated doing something like this in PAfE a few years back and the best I could come up with at the time was to just get Excel to call the keyboard shortcut to recalculate using the SendKeys application method, in this case Shift+F9, but you can adjust the keys depending on your use case. Below in the simplest form:
Sub RecalcSheet()
' Recalculate Sheet using shortcut key
    SendKeys "+{F9}"
End Sub
It does require the custom report setting to refresh data on Excel recalc keys, but in my experience these hotkeys seem to work in PAfE even if this setting is not enabled.
Not sure if this is the best alternative way but certainly one that worked for me!
