In theory if I have a view created through MDX in server, I use this view on a book and then run a ti through action button in PAW to update view's mdx it must update my view based on TI in my book as per the new MDX supplied in TI. but in practice paw doesn't do that.
The view remains static till user reopens that book.
Atleast not in my setup..
Any reason why I can't do this in paw? AmI missing my settings or configuration?
Is there any option to achive the same?
View mdx offers much more granular control over a view than MDX based subset.
Lav
Dynamic view update using ViewMDXSet in PAW
- Version: PA 2.0.9.1
- Excel Version: 365
Re: Dynamic view update using ViewMDXSet in PAW
I'm guessing you're just changing dimension selections/subsets in the view and not trying to render a completely different cubeview right? You could use a parameters cube to store the mdx parameters and have the cube mdx reference that cube for dimensions selections within the query.
- Steve Rowe
Hi Lav4you,
I would imagine what is going on is something like this.
You define view A which is contained in PAW screen B.
User opens PAW screen B, at this point PAW screen B has a local copy of the view A which is the user is free manipulate and navigate subject to rights etc.
You change the defintion of view A on the server using TI, this doesn't impact the PAW screen since it has its own local copy.
Assuming the user hasn't changed the view your MDX will still be excuting though.
What I would suggest is that rather than changing the MDX programmatically you'll need to extend the MDX defintion to generalise it so that the result can be manipulated in real time based on values held in cubes or the MDX on set defeinitions. Hard to be specific without more detail on your use case.
There is also a button to reload the defintion of a view from the server but this doesn't really solve your problem.
HTH
HTH
Thanks ascheevel.ascheevel wrote: ↑Wed Mar 01, 2023 9:32 pm I'm guessing you're just changing dimension selections/subsets in the view and not trying to render a completely different cubeview right? You could use a parameters cube to store the mdx parameters and have the cube mdx reference that cube for dimensions selections within the query.
I am aware of this option. I am just exploring if there is any option to update view rather than subset.
Lav
Exactly.. I am wondering if there is any hidden configuration option which I have missed that would enable the dynamic TI and MDX driven Views in PAW?Steve Rowe wrote: ↑Thu Mar 02, 2023 9:32 am Hi Lav4you,
HTH
