Hierarchy security update require a call to SecurityRefresh Function
lav4you
Post by lav4you »
I am facing a strange behaviour in PA.
I update a security through TI for an alternative hierarchy.
The process is very simple. It uses the following function to update security.
 HierarchyElementSecurityPut(sElSecurity, pDim, pHierarchy, sElName, sGroup) ;
Elements for which I am update security are 'C' level elements
Strangely it requires function to take effect of this update or else hierarchy is not accessible to user.
SecurityRefresh
I dont understand why it require a call to Security Refresh function when the }ElementSecurity cube does not have any rule?
I think I should mentioned this. There are two process which runs. The first one will recreate the hierarchy
and second process is called from epilog of the first, updates the security for this hierarchy.
Any help here ? I am missing anything about security on Hierarchy?
Lav
Re: Hierarchy security update require a call to SecurityRefresh Function
I agree this sounds strange. If element security cubes don't contain rules then the ElementSecurityPut function should be sufficient to update security without needing a SecurityRefresh.
MarenC
Excel Version: Excel 2016
Post by MarenC »
Do you have any cube or dimension security rules on the model?
Maren
Think I had something similar and ended up adding this along with the HierarchyElementSecurityPut statements iirc:
#--Give Access to see a particular hierarchy in the dimension
CellPutS(sElSecurity, '}DimensionSecurity', pDim | ':' | pHierarchy,  sGroup);
BR, George.
lav4you
Post by lav4you »
MarenC wrote: Thu Feb 09, 2023 1:20 pm Hi,
Maren
No. no rule on any dimension or '}ElementSecurity' cube.
lav4you
Post by lav4you »
gtonkin wrote: Thu Feb 09, 2023 2:22 pm Think I had something similar and ended up adding this along with the HierarchyElementSecurityPut statements iirc:
I will give it a try and let you know
lav4you
Post by lav4you »
I tried the CellPutS but the trick didnt work. :-(
lav4you wrote: Thu Feb 09, 2023 4:55 pm I tried the CellPutS but the trick didnt work. :-(
Maybe also try CellPutS to the element security cube. What George said rang a bell and I think I can recall needing to do this. (Why I don't know becasue AFAIK ElementSecurityPut should alone be adequate).
HierarchyElementSecurityPut(sElSecurity, pDim, pHierarchy, sElName, sGroup);
CellPutS(sElSecurity, '}ElementSecurity_' | pDim, pHierarchy:sElName, sGroup);
