MDX - How to identify empty subset through MDX
lav4you
Post by lav4you »
I would like perform a dynamic operation on a subset such that,
IF FILTER MDX Expression returns empty subset then use different subset else use the same.
IIF(
	ISEMTPY(   FILTER(TM1SUBSETALL([Employee]) , [Employee].[State]) = "Active"  ) ,
	[Employee].MEMBER,
How to achieve this through MDX?? Any thought?
Re: MDX - How to identify empty subset through MDX
I am thinking that you may have found a use-case for TM1TupleSize!
BR, George.
Here is an example that might guide you in the direction of a solution.
StrToSet( Iif( Count( Filter( TM1SubsetAll([Company]), [Company].CurrentMember.Properties("Active") = "Y" )) > 0,
"Filter( TM1SubsetAll( [Company]), [Company].CurrentMember.Properties(""Active"") = ""Y"" )",
"TM1SubsetAll([Company])" ))
If there are Active companies, filter those out.
If there are No Active companies, return all companies.
The function StrToSet is not my favorite. Working with text to generate an MDX query is second best in my opinion.
lav4you
Post by lav4you »
Thanks gtonkin.
Thanks Wim, I have done exactly that IIF and Count.
I got this idea from your website with amazing pool of MDX examples.
Thanks for that..
Lav
You’re welcome, glad you have a solution.
