we finally updated our Environment to use PAW, so it's my first time install PAW and everything was very straight forward, I switched the http and https port cause we running IIS (windows Server 2019).
Works fine so far, i configurated the IIS with a reversed Proxy rule to the PAW Port,but analytics returns the url with the PAW Port and not with port 80.
Any idea how i can fix this?
We are running ARC and TM1 Web on the same server, i can use both without this issue, just PAW redirects me back to the application port.
Thanks for your insights!
BR
PAW installation - using IIS Reversed Proxy
- Version: 2.0.9
Re: PAW installation - using IIS Reversed Proxy
Within pmhub.html file stored in cognos analytics I suspect the paw port is specified instead of the proxy path. Try changing that?
- OLAP Product: TM1 / TM1 Web / Perspectives
- Version: Planning Analytics V2.0.9
thanks for your insight, you are right, i also specified the PAW Port cause when just specified the Proxy Port i got the Error Message that- "The PMHub service parameter was not specified or is not one of the configured locations."
In the Dev console i can see the message " The URL PAWHOST:7777 is not whitelisted"
BR
BR
