Reverse engineering existing workbooks. Is there a method to document all DBRW's in a worksheet/ workbook
JohnO
Version: 2.0.9.x
Excel Version: Office 365 16
Post by JohnO »
I'm wondering if there is any existing method / has anyone written and VBA code to basically scan a worksheet/workbook and extract a list of all DBRW's/ DBR's (Maybe other worksheet functions) and the parameters being referenced (If they are formula parameters then the values that the parameters convert to). So the extract would basically be: Worksheet name, cell address, full formula containing the evaluated parameters).
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: Reverse engineering existing workbooks. Is there a method to document all DBRW's in a worksheet/ workbook
Post by ascheevel »
This might be a good starting point for you writing your own solution.
Mike Cowie
Version: Anything thru 11.x
Post by Mike Cowie »
JohnO wrote: ↑Tue Nov 29, 2022 10:14 pm I'm wondering if there is any existing method / has anyone written and VBA code to basically scan a worksheet/workbook and extract a list of all DBRW's/ DBR's (Maybe other worksheet functions) and the parameters being referenced (If they are formula parameters then the values that the parameters convert to). So the extract would basically be: Worksheet name, cell address, full formula containing the evaluated parameters).
Hi JohnO,
Not sure if this free, TM1-specific Audit Report tool, which you can download from here, might be of use.
Mike Cowie
QueBIT Consulting, LLC
