Feeders evaluation
Posted: Wed Nov 02, 2022 2:54 pm
by ultrakocka
we've had problem with time taking server to start, most time consumed by processing feeders in one cube. Colleague updated most rules in the cube in this fashion:
['item':'cost_per_unit']=>['item':'total_cost'];
['fiscal_year':{'2020','2021','2022'},'item':'cost_per_unit']=>['item':'total_cost'];
and the start-up time got to almost half. Fiscal_year is a dimension with elements 2000 to 2030. But there are data ONLY for 2020,2021,2022, so no more feeders are actually set compared to previous state. I would never expect this, but in retrospect can make sense. Has anyone encountered this? Should all feeders (in large cubes) be written as specifically as possible even though nothing is fed because of 0 values? I'm confused.
Thanks for opinions!
Re: Feeders evaluation
Posted: Wed Nov 02, 2022 3:13 pm
by Elessar
Your "zero" years can be overfed by a feeder like
['Something'] => ['fiscal_year':'Total years']
and feed further other zero cells.
And seriously, this "=>['item':'total_cost'];" feeder would confuse me more than your question.
Posted: Wed Nov 02, 2022 3:25 pm
by MarenC
I would hope not or that would incur some extra admin resource if feeders needed to be updated, for example to account for a new years data!
Posted: Wed Nov 02, 2022 5:05 pm
by gtonkin
Why not create a rollup of relevant years and reference that on the left?
Children (Leaf elements) of that rollup are then used to feed to the right.
Posted: Thu Nov 03, 2022 7:40 am
by ultrakocka
My question is why given cube like this (with more dimensions, large cube, just simplest slice for reference)
- Capture.PNG (7.83 KiB) Viewed 3154 times
feeder
should take longer to process than
or as gtonking and MarenC (Thanks!) pointed out, better would be this, to reduce maintenance overhead:
['fiscal_year':'C_planning_years','item':'cost_per_unit']=>['item':'total_cost'];
Why does it take longer given the other years 2015-2019 are empty? Hope this makes sense.
Thanks!
Posted: Thu Nov 03, 2022 8:46 am
by MarenC
I think Elessar was asking the question, is 'item':'total_cost' a consolidated element?
Posted: Thu Nov 03, 2022 9:37 am
by ultrakocka
MarenC wrote: ↑Thu Nov 03, 2022 8:46 am
My bad, no it is not it's just total_cost=cost_per_unit * quantity. N level elements.
Posted: Thu Nov 03, 2022 12:03 pm
by MarenC
If you change to feed from Quantity, instead of cost_per_unit, do you get the same problem?
Posted: Thu Nov 03, 2022 12:31 pm
by ultrakocka
Yep, it's the same.
