Deleted objects resurfacing
Michael Barker
Version: 10.1.1
Post by Michael Barker »
I am in the process of moving from 10.1.1 to PA 2.0 (from one server to another). Copying the entire model's folder over.
Strangely, deleted objects (application folders, chores and even cubes) are reappearing once set up on the new server.
I can just re-delete these but is there anyway to not have to do this manually? i.e. ensure these objects are deleted and not just "marked" as deleted.
Thanks in advance.
Re: Deleted objects resurfacing
How are you deleteing the objects?
If direct from the file system is the DB running while you do the delete?
Michael Barker
Version: 10.1.1
Hi Steve,
The objects were deleted directly from Architect.
