SUCCES charts - water fall charts
mrdauduong
Version: PA 2.0.74.23
Excel Version: Excel 2016
Post by mrdauduong »
hi,
i have an client who want to do a SUCCESS charts (or waterfall charts). they need to comparer 2 versions and check the reason by various aspect (for exemple, by section, by month)...
is waterfall charts can do this? (everything, i got the sum colum at the end, i can not put 2 colums versions at the same level)
this is the best thing i can do until now :D (last colum is a sum and i can chose only 1 measure for comparer)
thank for your help.
best i can do waterfall charts.png (41.67 KiB) Viewed 25528 times
cube reporting succes charts.png (133.65 KiB) Viewed 25528 times
ask by client.png (52.7 KiB) Viewed 25528 times
Re: SUCCES charts - water fall charts
Crossposted on the IBM PA forums.
mrdauduong
Wim Gielis wrote: Mon Oct 03, 2022 7:18 am Crossposted on the IBM PA forums.
hi Wim Gielis,
new in this forum, what you means when you said "crossposted"? (i posted in IBM PA community this post too while hoping a reponse), is this a problem?
thank for your reponse.
mrdauduong wrote: Mon Oct 03, 2022 2:25 pm
hi Wim Gielis,
At the very least, inform both places of the other location.
Do you expect volunteers spend time and effort when somewhere else it is already solved or more information is available ?
mrdauduong
Wim Gielis wrote: Mon Oct 03, 2022 3:39 pm
hi Wim Gielis,
thank. i will make attention next time.
probleme solved.
problem solved.PNG (82.32 KiB) Viewed 25407 times
mrdauduong wrote: Mon Oct 03, 2022 3:42 pm
hi Wim Gielis,
probleme solved.
Are you serious ? You created 12 topics in the IBM community, most of which are overlapping with the many topics here. None of them will contain a cross-reference. Please don't expect any help from my side.
mrdauduong
I want to ask a question in both place, and i try to say "it is finised" or "problem solved" when i got the reponse from 1 of community.
What you advise me to do?
Iam new in this forum, just tell me what i need to do and i will follow the rule.
Thank!
Wim Gielis wrote: Sun Oct 09, 2022 6:51 pm
probleme solved.
mrdauduong
None of them will contain a cross-reference ==> what you means? that means when i post something on IBM community (other side) and i post same thing here, i should post the link of the both place? right?
sorry for my bad english.
If this is what you means, i will do it from now (and correct all my post before) :geek:
mrdauduong
just update all the IBM community cross posted link on all my old post.
thanks !
i will make attention for the next time
probleme solved.
mrdauduong wrote: Mon Oct 10, 2022 7:52 am just update all the IBM community cross posted link on all my old post.
thanks !
Thanks. Vice versa as well: updating posts here with the link to the IBM posts. We’re you in such a hurry that1 posting in 1 community was not sufficient ?
mrdauduong
Wim Gielis wrote: Mon Oct 10, 2022 8:27 am
thanks !
Vice versa as well: updating posts here with the link to the IBM posts. => just did for all post on IBM community and TM1 forum.
We’re you in such a hurry that1 posting in 1 community was not sufficient ? ==> for now, i dont know which community is better, so, i post in both community with hope for a reponse. but i will make a choice later for sure.
Most of time, i got a good reponse in here.
But sometime (for ex: for this question) i got a good reponse in IBM community.
thanks for your reponse !
