Has anyone had an success with placing a Tm1Web object (websheet) in a dashboard
that can be recalc'd ?? I have been able to launch the web page but it
is not logged in even though I am using intergrated login in Tm1web.
If anyone has any code or procedure for doing this - it would be much appreciated.
Thank
Lewis
Tm1Web URL link
Lewis
- OLAP Product: Cognos Tm1
- Version: 952 FP1 [prod]
- Excel Version: 2007 2010
Re: Tm1Web URL link
I am running 910 sp3 server and web .
* no issues
* no issues
- Eric
- Version: 9.4
- Excel Version: 2003
Re: Tm1Web URL link
Not sure I understand the question, but I have a few either way.
IE or FF? I think it does but I am not sure if that version support FF.
Also check you browser integrated login setting
http://forums.olapforums.com/viewtopic. ... login#p392
If that doesn't help let me know
Eric
Eric
Lewis
Re: Tm1Web URL link
IE 7 - integrated login works fine with normal Tm1web page
I have a URL link that will open a websheet but it does not log me in to Tm1 ,
missing something in the process - Tm1 documentation could be a little better
Re: Tm1Web URL link
I can't answer the integrated login question (our web users generally access it through a VPN and fob key so it's not really a viable option for us even if we wanted it which, to be honest, I don't), but in general 9.1 SP3 does support Firefox... kinda. And only after you tweak the FF configuration.Eric wrote:Not sure I understand the question, but I have a few either way.
The problem is that the display looks like crud. For example if you have the gridlines turned off in a websheet then the display will be correct in IE (6 or 7), but the gridlines will still be visible in FF. Also, even if you insert graphics as .pngs (which is the only way to avoid jaggies in websheet graphics which are viewed in IE), the graphics will look like they were drawn by a 2 year old in FF. A 2 year old who's really bad at keeping inside the lines.
I haven't dared even try Safari.
I BS my way through this in my end user training materials by saying that "You should only use IE because TM1 Web has been optimised for it, blah, blah"... but the reality? I suspect that as soon as the development team got a websheet to display AT ALL in FF, they just ticked the box and said "Yup, supports FireFox!"
- Steve Vincent
- Version: 10.2.2 FP1
Re: Tm1Web URL link
Lewis wrote: Tm1 documentation could be a little better
