Hello All,
We are in the midst of upgrading our old TM1 (10.2.2) servers to PA. There are a few Cafe templates and those would need to be converted to PAX. The conversion seems to be working fine if the server name is same in both the versions. However, it doesn't seem to work if the server name is different. I have tried manually changing the server name, but that doesn't work as well. Is it true that the 'Update Connection Utility' in PAX works only if the server name is same or is there a workaround?
Thank you in advance for your response.
Cafe to Pax conversion with a different server name?
bubidibabadi
- Version: 10.2.2, Planning Analytics wit
bubidi.
bubidi.
