about asciioutput add quote issue
Niko
OLAP Product: IBM Cognos TM1
Version: PA 2.09 / TM1 11.7.00000.42
Excel Version: EXCEL 2019
Post by Niko »
as my local system has a .py file, now i want to use asciioutput genarate a file as it( prolog genarate and epilog execute), but after i open it with notepad++ , as system auto add quote on Both sides of each line, which result in executecommand can not execute successfully, it's very strange,I don't know if anyone has ever had this problem?
Any help would be greatly appreciated.
mannual create .py file:
import asyncio
import nest_asyncio
nest_asyncio.apply()
from concurrent.futures import ThreadPoolExecutor
from TM1py.Services import TM1Service
from typing import List
import time
asciioutput genarate .py file:
"import asyncio"
"import nest_asyncio"
"nest_asyncio.apply()"
"from concurrent.futures import ThreadPoolExecutor"
"from TM1py.Services import TM1Service"
"from typing import List"
"import time"
Re: about asciioutput add quote issue
Niko wrote: Sun Jul 03, 2022 5:08 am as my local system has a .py file, now i want to use asciioutput genarate a file as it( prolog genarate and epilog execute), but after i open it with notepad++ , as system auto add quote on Both sides of each line,
To produce it without the quotes, set this variable to a null string in the prolog.
DatasourceASCIIQuoteCharacter='';
Niko
Post by Niko »
Alan Kirk wrote: Sun Jul 03, 2022 6:20 am
I get it, and it works , thank you very much.
