MDX - Using VAL instead of StrToValue
For as long as I can remember we have been using StrToValue in MDX when filtering.
The catch has always been that where values have not been set and are effectively null, you needed to use an IIF() statement to trap for this and resolve by substituting a "0".
The VAL() function seems to be the function we all wanted but did not know about e.g.
FILTER({TM1SUBSETALL( [Period] )}, VAL(LEFT([Period].CurrentMember.Name,4))=2022)
What seems to be very useful is you can use VAL() against a numeric attribute e.g.
FILTER(
{TM1SUBSETALL( [Scenario] )},
VAL([Scenario].CurrentMember.Properties("Flag"))=1)
For C levels and other N levels where flag was never specified and shows a 0, these do not result in an error like StrToValue and the need to use IIF. Changing the above MDX to filter on a value of 0 returns those members either set to 0 or never set.
Remember that numeric attributes are actually treated as strings so my flag with a value of 1 is actually seen as "1.000000". Using VAL() I can simply compare the value in the attribute or cube to a numeric value.
There are some other lesser known functions that may be worth mentioning too:
LEN(<string>) - like Excel, get the length of something
LEFT(<string>,<characters>)
RIGHT(<string>,<characters>)
UCASE(<string>) - Upper case
LCASE(<string>) - Lower case
CASE e.g.
{STRTOMEMBER("[Period].[" +
CASE LEFT(RIGHT(SetToStr({[Period].[Current Month].Item(0)}),9),7)
   WHEN '2021/03' then '2021-Q1'
   WHEN '2021/04' then '2021-Q2'
ELSE
END
Hope these extend your MDX knowledge a bit more!
BR, George.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: MDX - Using VAL instead of StrToValue
Post by Elessar »
Wow, thanks George!
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Hi George,
Another wow from me! Just wished you had shared this like 5 years ago!
I knew about all the others except the VAL, though I don't see much need to use UCASE and LCASE since you pointed out the 4th parameter of INSTR could be used to turn off case sensitivity!
regards,
Mark
