Subset Picklist not refreshing
Paul-TM1
Post by Paul-TM1 »
Hi Gurus,
We are using PA - 2.0.9.5 version.
I have changed a subset list elements - used as a picklist - in a cube and the new values do not showup in architect/Perspectives. Worse is, the old elements show in dropdown up even after I deleted the "subset:Dimension:SubsetName" from edit element attributes and have run out of ideas to fix. Can some let me know if there's a fix for this?
Luther.
Re: Subset Picklist not refreshing
Check if there is a }picklist cube - if there is, it will take precedence over the attribute picklist setting.
A generic TI process that I wrote very recently, can be found here:
https://www.tm1forum.com/viewtopic.php?t=16101
Paul-TM1
Post by Paul-TM1 »
Thank you verymuch Declanr and Wim. }picklist cube was the reason.
Also how would I refresh the picklist?
Thanks a ton!
Paul-TM1 wrote: Thu Jan 27, 2022 3:51 am Thank you verymuch Declanr and Wim. }picklist cube was the reason.
IBM has documentation online:
https://www.ibm.com/docs/en/planning-an ... pick-lists
