Picklist FOR (not 'with') element attribute
wbf
Version: 10.2.0
Post by wbf »
Is it possible to create a picklist for element in }ElementAttribute_dim?
For example, customer dim has string element attribute called 'gender', I want to control the input by allowing only 'F' or 'M'
Its like element attribute of element attribute. I've tried creating a static one. a new dimension was created with name '}ElementAttribute_ElementAttribute_dim' but the dropdown doesn't seem to appear. 8-)
Can't find any info online - the keyword 'picklist' and 'element attributes' yields only ways to 'create picklist with element attribute', not 'creating picklist for element attribute'.
Thanks in advance
Re: Picklist FOR (not 'with') element attribute
Not sure if an attributes cube supports picklists.
Have you tried a real picklists cube ?
Also, a regular cube instead of an attributes cube will do too. It might be a bit rework in your application but it will work fine.
Picklists work in }ElementAttribute_ cubes.
You just need to create a picklist cube and define a rule for the picklist.
wbf
Version: 10.2.0
Post by wbf »
Thank you guys,
It works just fine!
