PAX RefreshAllData()
Posted: Wed Nov 03, 2021 12:40 pm
by RonLat
There is a function in PAX that allows to refresh the DBRW formula in a excel worksheet using VBA.
Preparations
- The file CognosOfficeAutomationExample.bas is imported into the VBA project
- The file CognosOfficeMessageSuppressor.cls is imported into the VBA project
- PAX is connected to the TM1 server
- A view from the Sdata cube is present in the worksheet (DBRW formulas)
Example 1
Sub refreshData()
CognosOfficeAutomationObject.RefreshAllData
End Sub
Result: Run time error '424': object required
Example 2
Sub refreshData()
ActiveWorkbook.Worksheets("TAB1").CognosOfficeAutomationObject.RefreshAllData
End Sub
Result: Run-time error 438: Object doesn't support this property or method
Example 3
Sub CalculateOneWorksheet()
ActiveWorkbook.Worksheets("TAB1").Calculate
End Sub
Result: The normal VBA function Calculate runs without errors, does not update the DBRW formulas though.
Does anybody have a hint how to use the RefreshAllData function with PAX in VBA?
Re: PAX RefreshAllData()
Posted: Wed Nov 03, 2021 1:00 pm
by gtonkin
Example 1 works in my books.
I had an issue previously with the IBM Framework for Office clashing with something when I updated to PAW 2.0.65
What version are you on? Did you previously enable the IBM Framework for Office as a COM add-in as well?
With PAfE 2.0.65 onwards, make sure that all PAfE and the IBM framework have been uninstalled.
I had an issue where my installation was not showing in Add or Remove Programs and I had to run the Uninstall from the folder in C:\Program Files\ibm\cognos\. Once this was removed and I restarted Excel with PAfE, in my case 2.0.67, all worked as expected.
Posted: Wed Nov 03, 2021 3:01 pm
by flecky
I was having issues with refreshing data using VBA but I found something on the ibm git page
https://ibm.github.io/paxapi/#refreshsheet
Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshSheet
I use as a simple refresh and also for dynamic report rebuilds in PAfE 2.0.68. In the VBA itself I have never imported CognosOfficeAutomationExample.bas or CognosOfficeMessageSuppressor.cls into the project but it seems to work fine and has done for the last few versions at least.
Posted: Thu Nov 04, 2021 8:28 am
by RonLat
Environment
- Microsoft Excel for Microsoft 365 MSO (16.0.13127.21210) 32-Bit
- IBM Planning Analytics for Microsoft Excel Version 2.0.68.4
- Aktive COM-Add-In: IBM Planning Analytics for Excel Addin
- Aktive COM-Add-In: IBM Planning Analytics for Excel Addin (Custom Task Pane Helper)
What I tried so far:
Sub refreshData()
' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshBook
' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.Application("COR", "1.1").RefreshAllData
' Application.COMAddIns("CognosOffice12.Connect").Object.AutomationServer.RefreshAllData
End Sub
When I hit the F5 key within the Sub in the VBA editor, in all cases I get the error
Runtime error '91': Object variable or With block variable not set"
What do they mean by "Object variable" or "With block variable" that needs to be set?
I wonder also, how VBA would know which sheet to refresh, if I only say RefreshSheet?
Posted: Thu Nov 04, 2021 11:41 am
by RonLat
I tried to check, what COMAddins are installed on my system.
Sub refreshData()
Dim var1
For Each var1 In Application.COMAddIns
Debug.Print var1
Next
End Sub
Result
- Microsoft Power View for Excel
- IBM Planning Analytics for Excel Addin
- Microsoft Power Map for Excel
- IBM Planning Analytics for Excel Addin (Custom Task Pane Helper)
- Microsoft Data Streamer for Excel
- Microsoft Power Pivot for Excel
There ist no
CognosOffice12 in this list, so
can not work at all. What's the deal with the CognosOffice12? Where does it come from?
Posted: Thu Nov 04, 2021 4:46 pm
by gtonkin
Still fairly certain that you need to uninstall IBM framework for Office as you are running PAfE 2.0.68
Posted: Fri Nov 05, 2021 8:01 am
by RonLat
There is a workaround regarding this problem and it is described only in one place on the internet.
IBM Framework for Office and PAfE 2.0.66 installs.
https://community.ibm.com/community/use ... gestviewer
Old PAX: CognosOffice12.Connect
New PAfE: CognosOffice12.ConnectPAfEAddin
Working calls of the refresh functions:
Sub refreshData()
' Call over object variable
Dim CognosOfficeAutomationObject As Object
Set CognosOfficeAutomationObject = Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer
' direct call
Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.Application("COR", "1.1").RefreshBook
Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.Application("COR", "1.1").RefreshSheet
Application.COMAddIns("CognosOffice12.ConnectPAfEAddin").Object.AutomationServer.RefreshAllData
End Sub
So, for now the problem is kinda solved, till IBM changes something in the near future and it crashes again
Posted: Tue Nov 09, 2021 10:34 am
by Paul Segal
Although if you read the whole link, this shouldn't be necessary. I'd be more concerned with getting the install right rather than amending the VBA code to partially fix something that's broken (and might fix itself in future, then giving you an issue with the VBA code that now no longer works).
Posted: Mon Jun 20, 2022 6:00 am
by Elessar
I've had another RefreshAllData fault with "91" error recently: DAX add-in caused this. Disabling it fixed the error
