I am using a MDX expression to pull current year from a lookup cube in subset. The values retrieved are native elements and are in fiscal year format, Quarter dimension has a calendar year attribute(CY Year) to display elements in CY format. Tried to use CurrentMember.Properties function but it didn't work, is there a way to display elements CY format using attribute CY Year in MDX expression?
MDX :
{STRTOMEMBER("[Quarter].[Quarter].[" + [Lookup Cube].([Comment].[Comment],[Description].[Current Quarter]) + "]").LAG(1) : STRTOMEMBER("[Quarter].[Quarter].[" + [Lookup Cube].([Comment].[Comment],[Description].[Current Quarter]) + "]").LEAD(20)}
Display Attribute value in MDX expression
aravind.cgns
- OLAP Product: Cognos Tm1
- Version: 10.2,11
MarenC
- Excel Version: Excel 2016
Re: Display Attribute value in MDX expression
Is the attribute an alias?
If so why don't you just switch on the alias?
Maren
Maren
aravind.cgns
- Version: 10.2,11
Hi Maren,
Thanks for the response, Yes attribute is a alias. I can turn it on works fine in TM1. I am actually trying to read view via REST API which only pulls native elements though i save my view with Alias turned on in the view. Looking for an option to turn on alias within MDX expression..
Arvind
Arvind
The Rest API will always return the principal member name under the object. However if you also request member properties then these will also be returned in the JSON under the attributes associated with the member. It is then up to whichever front end you are using to display either the member name, unique name or attribute(s).
aravind.cgns
- Version: 10.2,11
Thank a lot Lotsaram!!
I was able to retrieve the names , attributes by specifying it in tuple members. This has fixed my issue
