Morning All,
Does anyone have a little .xla or something that defaults any spreadsheet to manual calculations when opened, instead of calc'g it ?
Ajay
Auto Recalc - STRESS !!!
Paul Segal
- Version: TM1 11 and up
Re: Auto Recalc - STRESS !!!
Hi Ajay,
Here's a interesting (for certain values of interesting) link to a Microsoft KB that illuminates the auto recalc behaviour in Excel: http://support.microsoft.com/default.as ... us;Q214395 which should be of help.
Paul
Yeah, irritating, innit? There IS usually a way around it though which involves no VBA code at all.Does anyone have a little .xla or something that defaults any spreadsheet to manual calculations when opened, instead of calc'g it ?
As I understand it Excel will adopt the calculation setting of the last opened file at startup, though since calculation is a global setting (rather than a workbook one) it will ignore the settings of any subsequently opened files.
(The calculation mode is apparently buried somewhere in the file, even if it's not an exposed property.)
The secret is therefore to make sure that the last-opened file at startup has a manual calculation mode.
Most people don't open files at start-up (aside from the odd .xla perhaps) but rather start with a blank workbook, the ubiquitous "Book1". What you therefore have to do is make sure that the blank workbook has a manual calculation setting.
Unless you specify otherwise, Excel will use its own internal settings for blank workbooks, including automatic calculation. To substitute your own, you need to create a new global template as follows:
- Close down any workbooks that you have open in Excel;
- Open up a new blank workbook;
- Change its calculation setting to Manual;
- If you feel inclined, take the time to make any other changes that you like. Don't like Arial 10 as the default font? Redefine the Normal style. Want 4 sheets instead of 3? Add one, and so on.
- Find the folder called xlStart. This will typically be on a path like
C:\Documents and Settings\{UserName}\Application Data\Microsoft\Excel\XLSTART
- Save the modified workbook as an Excel template (.xlt) file named Book.xlt (NOT Book1.xlt, just book.xlt)
Thereafter when you open a session of Excel, the blank workbook that opens should have all of your updated styles and settings... including the manual calculation mode.
Oops, my memory lapse; as per the article mentioned by Paul, it's actually:Alan Kirk wrote: As I understand it Excel will adopt the calculation setting of the last opened file at startup,
Regardless, the book.xlt technique should still work.The first document opened uses the calculation mode with which it was last saved. Subsequently opened documents use the same mode.
- jim wood
- Version: PA 2.0.7
I have had real issues with this myself as I have a set of data templates completed by users. I have found that somtimes (Even thogu you have autocalculate siwtched off.) it remebers the setting from when the file was last saved and they always start loading data.
The only solution I ahve found is make sure you are not connected to any TM1 server when opening the file. Even if it set to auto calculate it comes back really quickly,
Jim.
Jim.
- Steve Vincent
- Version: 10.2.2 FP1
Orrrr you could use the addin i created and demo'd at the "TM1 User Conference of the North" last year
This puts a drop down box in to the menu bar with 2 options, calc suppress ON and OFF. ON will ensure any new or opened wb will have calculation turned to manual. OFF will make it auto calc. Note it only makes this change when a wb is OPENED or CREATED. Just selecting the drop down will NOT change anything
I'll add it to the thread of useful stuff later as well...
- TM1 Tools.zip
- ensures auto calc is always on or off, based on users needs
- (8.36 KiB) Downloaded 1712 times
