Hello Everyone,
Anyone can shed light on Planning Analytics Upgrade
While the Planning Analytics Upgrade was the Cube Rules were modified and added few lines of code :
#Region
FEEDSTRINGS;
SPIKCHECK;
#EndRegion;
for few cubes.
Do we know, if IBM has added anything like this within Upgrade Process, to add lines of code as above?
Appreciate, if anyone knows or has faced a similar issue please share the steps. Cheers
Planning Analytics Upgrade added lines of code in Cube Rule Editor
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: Planning Analytics Upgrade added lines of code in Cube Rule Editor
Do you use Performance Modeler? (if yes, I recommend to stop using it)
As far as I remember, it is the only one who add this lines of code. If you do not need SKIPCHECK in some cubes, double-click them in PM and select and deselect the option for automatic SKIPCHECK adding
