Hi Experts,
I am able to write few simple rules, but I do not know the basics of rules and feeders , oer feeding under feeding , more than 1 cubes , consolidated level , N level . . I am ery comfortable at writing some TI process with some functions.
Any advice on where to start reading more about feeders and rules.I am very interested to learn , so any advice on a link or book to get started and practise will be very useful .
Tm1 Rules and Feeders
Adam
- OLAP Product: IBM PA
- Version: 2.0.9.x
- Excel Version: Microsoft 365 x64
Re: Tm1 Rules and Feeders
Hi Manu,
By no means am I an "expert". My years of experience with TM1 is significantly fewer compared to most of the individuals on here. I am nonetheless excited by this question as I can still vividly remember a time before TM1 and the path I took to learn. Therefore. I can certainly help point you in the right direction.
With regards to rules and feeders, what I will say is "you can do it"! Feeders upfront seems like a complex topic, but with practice, you will get the hang of it. Let me give you three solid references on the topic of rules / feeders. Work through the first one, once you have the hang of it, move on to the second document, etc.
Just a few additional pointers that I had on a sticky note to keep reminding myself when I was new in the space of rules/feeders:
- White Paper: A Best Practice Guide to Developing TM1 Rules -- Concise document by Cubewise on how to write rules in TM1. I read the document cover to cover multiple times when I was first going down this journey.: https://static1.squarespace.com/static/ ... _Rules.pdf
- IBM Cognos Proven Practices: IBM Cognos TM1 FEEDERS -- Document written by IBM a number of years ago. Although it's flagged as "advanced", it was pretty useful to me when I was brand new. I've gone through this document cover to cover multiple times as well: https://www.decisionsystems.com/wp-cont ... ctices.pdf
- 7 tips to writing faster IBM TM1 and Planning Analytics rules -- Once you really understand rules and feeders, this blog article by Cubewise is pretty useful: https://code.cubewise.com/blog/7-tips-t ... tics-rules
- Practice, practice, practice. Write the business logic in Excel then translate it to TM1.
- For FEEDERS; ['X'] => ['Y'];
- Y is most likely non-zero when X is non-zero. FEEDERS always build up from this fundamental principal.
- Y can be substituted with DB() to point to another cube.
- FEEDERS serve two purposes:
- Flag a cell to be consolidated.
- Flag a cell to be not zero suppressed.
- When you write a rule that references:
- A leaf-level cell (assuming sound logic): The answer will always be correct, meaning FEEDERS don't determine right/wrong answer when referencing leaf-level cells.
- A consolidation: If that reference consolidation cell has unfed member cells, your answer will be wrong.
- Alan Kirk is always right.
manu0521
- OLAP Product: IBM TM1, Planning Analytics
- Version: PA 2.0.5
Thanks a lot Adam for taking time to give some references and for being so supportive. I will look in to them one by one and start practising. Yes the members on this forum has been very supportive and i wanted to do some homework before getting to them in case of any issues.
