Does anybody see why this string rule will not work? TM1 say that there is a logic error before ['USP','Post Period']:
['IRA-USP','Post Period']=S:if(['USP','Post Period']@='',['IRA','Post Period'],['USP','Post Period']);
Post Period in this example is a String element. I have also created a rule where there is no if statement and IRA-USP is just equal to USP with no luck either. Is there something that I am missing in my rule.
String Rule
- Mike Cowie
- Version: Anything thru 11.x
Re: String Rule
You can't use internal cube references ([...])for any returned string data in a rule. You need a DB() reference instead. I don't know your cube and its dimensions, so the best example I can give you is a bit fake to illustrate:
Putting it another way, when TM1 sees the internal cube references it always assumes a number is coming out of that and, because this rule is String-based it won't allow it to compile.
Mike
['IRA-USP', 'Post Period']=S:
if(DB('YourCube',!OtherDim1,!OtherDim2,'USP','Post Period')@='',DB('YourCube',!OtherDim1,!OtherDim2,'IRA','Post Period'),DB('YourCube',!OtherDim1!OtherDim2,'USP','Post Period') );Regards,
Mike
Mike Cowie
QueBIT Consulting, LLC
cdhodge2002
Re: String Rule
Awesome, thanks. If all my issues were only so easy
