Break function
Break function
I know that the Break function is not supported in TI. But in the past it never bite me, until today.
Looking at this code:
 c = 1;
 While( c > 0 );
	If( 'X' @= 'Y' );
	   Break;
	EndIf;
	c = c + 1;
	If( c > 3 );
	   Break;
	EndIf;
 End;
The process will run forever and bring the TM1 server to the ground. Why ?
The first IF is never True.
The second IF should be executing and lead to a Break and escape the loop, it does not.
Now here's something important: if I uncomment the first Break, the second executes !
So it looks like you cannot have 2 Break statements within the loop.
Did anyone come across this one ?
Emixam
Re: Break function
Post by Emixam »
Hello Wim,
I notice this behavior couple months ago. I just ran your code and was stuck in a infinite loop.
However, if you have nested while loops it will works (as long as there is only 1 break statement in each loop)
This will be executed successfully:
i = 1;
WHILE( i > 0 );
	IF( i > 10 );
		Break;
	ENDIF;
	c = 1;
	WHILE( c > 0 );
		IF( c > 3 );
			Break;
		ENDIF;
		c = c + 1;
	END;
	i = i + 1;
END;
Ever since I realized this issue I'm using a numerical value as a break statement:
c = 1;
While( c > 0 );
	If( 'X' @= 'Y' );
		#Break;
		c = -1;
	EndIf;
	c = c + 1;
	If( c > 3 );
		#Break;
		c = -1;
	EndIf;
End;
I am using PA 2.0.8
Re: Break function
Thanks for the confirmation, these were exactly my thoughts too.
I think I will continue using Break and make sure there's only 1 of it, if there are 2 then yes, a numeric value will do.
I just find Break so much better than escaping loops with numeric values like -1 or 0 or 999 or some such.
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Re: Break function
Post by Mark RMBC »
Hi Wim,
I use Break too, so this is good to know.
If you put Sleep (100) before the first Break does this resolve it?
Interestingly adding an asciioutput into both IF statements outputs 2 files if a break statement is there.
regards,
Mark
Re: Break function
Mark RMBC wrote: Fri Apr 16, 2021 9:55 am Hi Wim,
regards,
Mark
Yes, the Breaks are ignored leading to endless loops too.
Mark RMBC
Version: 10.1.1
Re: Break function
Post by Mark RMBC »
Hi Wim,
so the code below also leads to an endless loop?
 c = 1;
 While( c > 0 );
	If( 'X' @= 'Y' );
           Sleep(100);
	   Break;
	EndIf;
	c = c + 1;
	If( c > 3 );
	   Break;
	EndIf;
 End;
Interesting it doesn't for me.
Mark
Re: Break function
I haven’t tried Sleep yet, I should do that more by the way !
Emixam
Re: Break function
Post by Emixam »
Apparently, replace the Sleep() function with any other functions/line of code and the process will still be completed successfully !
  c = 1;
 While( c > 0 );
	If( 'X' @= 'Y' );
	   # Replace GetProcessName() with something like z = 1 + 2 and it will still works !
	   GetProcessName();
	   Break;
	EndIf;
	c = c + 1;
	If( c > 3 );
	   Break;
	EndIf;
 End;
Re: Break function
Weird ! But then the advantage of the simplicity of Break is gone too 😉
