Action Button Bulk upload
Posted: Fri Apr 09, 2021 1:35 pm
I have discovered the Action Button to use a TI-Process to upload values directly to a cube.
I only succeeded with uploading one value to one leaf element, but I have values spread within an Excel range like b20:d500. Selecting a range for a parameter is not working, however.
I'm not exactly sure how to create a TI-Process to have an Action Button work in order to upload a set of values (for Example all Excel Values located in B20:D500). Having 500 different parameters created in the TI, to define each leaf element is no real solution, isn't it?
Is there a possibility to use the Action Button for a Bulk upload of values into a Cube without using a .csv format?
If not, is there any other way (besides quick-report with committing values to a cube)?
Thanks to all of you who will help me
