Contributor vs TM1web & Perspectives - Non-contributor users are not able to enter data in the cube
Posted: Fri Apr 09, 2021 6:22 am
Hello all,
I have a Approval-type contributor application with Cost_Center as approval hierarchy and Version as Control Dimension. There are several cube views in contributor and reviewer views. The workflow works fine but since workflow app was deployed, it locked all those cubes for non-contributor users (TM1web / perspectives).
The contributor app is mainly for budget user to enter their budgets in budget version. Hence, I used version control dimension. I thought having cellsecurity on cube will allow me to keep Forecast version open for non-contributor users to use TM1 web or Perpectives and enter their Forecast numbers and comments. But it is not the case
Am I missing anything here
Can I enable non-contributor users to enter Forecast data in forecast version?
