We have problem in our environment with ISB view via Perspectives in citrix. View can be opened without any problem, but when I hover my mouse cursor over title dimensions “buttons” to open subset editor (cells A2 and A3) then cursor starts blinking and citrix window is frozen and when I click when cursor is still blinking then citrix window stops responding and crashes(please see picture below). After that I can only close program and when I open Perspectives from citrix again then previous session is still there and situation repeats. If I don’t leave my cursor on those buttons and I quickly click to open subset editor then sometimes I am fast enough and subset editor opens.
I tested several versions of citrix workspace app. Our users have mostly 19.12.1000.1063(1912) which causes this problems. I tested it also with 21.02.0.25 (2102) which works better, but doesn’t solve blinking cursor and citrix crash completely. In the past we experienced similar problems with citrix receiver and also some versions were better than others.
Problem occurs only with ISB view, custom reports works fine.
Have you seen this before? Is there anything that can be set on citrix side or tm1 side?
Thank you for your help.
Matej
