Comments and threaded conversations in dashboards
Posted: Wed Mar 10, 2021 2:56 pm
Hallo All,
PAW Cell Comments are possible(the information is stored in a control cube called }CellAnnotations_CUBENAME).
I was also looking at this thread (viewtopic.php?p=7320), but still missing what I am after.
I want owners of certain dashboards be able to give comments, imagine a dashboard with personal data on it for a certain month, showing FTE, illness rate, overtime rate for a certain department.
Then the head of the department can give comments to this 'slide'.
For example illness rate april 2020 is high 34%, what is happening?
He could add a comment on that dashboard (name + time stamp) of that month in that department that Corona hits to workfloor hard.
So whenever you select april 2020, for department x, looking at the HR dashboard, you would see that comment.
When you move to may 2020, no comments on that screen.
If you would look at 2020, the comment will appear that for April a comment was added.
Hope this makes sense...
