SUBNM requires enter after selection
jed
Version: PA 2.0.9.4
Post by jed »
What is it that causes a perfectly normally functioning excel TM1 report to suddenly require ENTER after selecting a different element in a SUBNM formula (when it was not required previously)???
I've seen it many times before but I can't remember what causes it...
Re: SUBNM requires enter after selection
9.4.1 FP2 has a few bugs in how it handles incomplete SUBNM formulas. The issue you describe is usually preceded by a "VBA error 13: Type mismatch" in the tm1p.xla VBA module, this disables TM1 handling the double-click event that fires the subset editor until the code break is reset (usually be performing another action such as a fresh slice or possibly a recalculate would work as well).
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post by Gregor Koch »
Might want to give the good old 'Edit directly in cell' option a try.
jed
Version: PA 2.0.9.4
Post by jed »
HA - had a brain wave and I've cracked it!!!
It must be a bug (not sure if specific to this version - client version I'm on is 9.4 MR1). It is caused when you have a SUBNM formula in a merged cell. Unmerge the cells and SUBNM works normally again. It's a pain though cause frequently you need to merge cells in reports with SUBNM.
Does anyone know if this a bug logged with IBM or is it a "documented feature"?!
