Shared Sandboxing
garry cook
Version: Various
Excel Version: Various
Shared Sandboxing
Post by garry cook »
This periodically raises its head and I've just had another use case come up again for shared sandboxes. Just went to raise a ticket but on checking before posting, saw that someone had already raised a ticket with a handful of votes. It's showing as "Future consideration" currently which is ironic over 2 years on.
Just putting it here for visibility as it's a pretty fundamental gap in what should be a really big selling point of the product. Adding link for any potential traction from the wider communtiy. My faith is low but hope springs enternal and all that.
https://ibm-data-and-ai.ideas.aha.io/ideas/PAOP-I-38
Also, in terms of workaround, I realise it's just about do-able by pulling the loose objects within the data tier but it's a messy workaround prone to error so I've always steered clear of this in an operational environment.
Re: Shared Sandboxing
HI Garry, based on the AMA sessions, I am cautiously optimistic on this materialising "soon".
What I have done to emulate this is to have multiple active Scenarios - Rolling Forecast plus Active 1,2 etc.
The Active scenarios are flagged to be Live or Static and rules look at this.
I also have system rollups for the feeders to trickle feed as required.
High-level but HTH.
BR, George.
This was discussed during the AMA on Feb 11th.
The short summary is that it won't be in the v11 server. It is something they will work on after the launch of the v12 "next generation" server.
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Post by Adam »
lotsaram wrote: Fri Feb 12, 2021 3:50 pm This was discussed during the AMA on Feb 11th.
I think we were all on the same call ... my takeaway was that this is easily 2 years away.
Take care,
Adam
