SubsetElementInsert difference between Position Index=1 and =2 in behaviour
pikolikoli
OLAP Product: tm1
Post by pikolikoli »
Hello Everyone,
I was just testing some code and found a SubsetElementInsert like this :
SubsetDestroy(zDim , zView );
SubsetCreate(zDim, zView );
SubsetElementInsert ( zDim , zView ,'Elem 1', 1 );
SubsetElementInsert ( zDim , zView ,'Elem 2', 1 );
SubsetElementInsert ( zDim , zView ,'Elem 3', 1 );
I found That 1 is the position where we want to insert an element in subset. So what is the difference in behaviour between if I put my subset like this :
SubsetElementInsert ( zDim , zView ,'Elem 2', 2 );
SubsetElementInsert ( zDim , zView ,'Elem 3', 3 );
Why Are we inserting all the elements on the same position ? woudnt inserting all the elements in the same position erase the last inserted value so we will end up with only Elemnt3 ? and what will happend if we insert them in different position ? When should we use the first case and when should we use the second case ?
Thank you
Re: SubsetElementInsert difference between Position Index=1 and =2 in behaviour
Putting 1 as the index means insert it into the first position in the subset. All the other members will be moved down a spot.
pikolikoli
OLAP Product: tm1
tomok wrote: Wed Dec 23, 2020 2:57 pm Putting 1 as the index means insert it into the first position in the subset. All the other members will be moved down a spot.
Thank you very much I understand Now.
Use 0 everywhere if you want to insert elements in the order in which they are listed in the code.
