I get the error...
Warning There is a new version of xxx.str_step available. Please reedit the job to obtain the updated version, otherwise the job may fail to run.
This is a little perplexing to me, as I have the Object Version set to LATEST. Isn't the whole point of that so that it always picks up the latest SPSS stream? Why should I need to reedit the job every time I update the stream? I have override type set to Job Overrides Stream, but the documentation says this is just related to the credentials, which indeed I do want the job to override the stream.
Ray
CNDS Job Warning there is a new version of the xxx.str_step available.
- Steve Rowe
Re: CNDS Job Warning there is a new version of the xxx.str_step available.
Hi Ray,
I think you maybe lost...you've posted in a forum specifically about TM1 / Planning Analytics.
Could you edit your post to make it clear what product you are asking about? Someone maybe able to help or point you in the right direction..
