Pick list in Cognos Analytics from Tm1
Posted: Tue Nov 03, 2020 12:27 pm
by Palczan
Hello Everyone,
today I have a problem with picklist. I set in tm1 cube a picklist with element of dimension and everything is fine, but unfortunately when I add this cube to Cognos Anlytics I can't choose a element. Do you have a similar problem?
Best regards
Kamil
Re: Pick list in Cognos Analytics from Tm1
Posted: Wed Nov 04, 2020 11:10 am
by mvaspal
Do you mean you cannot access the picklist from CA? As CA is a read-only user interface, you won't be able to use picklists, only read the values from the tm1 cubes
