PAw range handle bars for Dimensions?
CTM1K
OLAP Product: PAx, PAw, TM1
Version: 4.0.x
Post by CTM1K »
Hi folks,
I've seen in some online presentations a type visualization of a Dimensions selector Widget (I guess) which allows you to select a range of Elements, by sliding with "handlebars" back and forth...
I would love to use this type of selection, but I don't know where to start.
Have you an idea of where to start or how to build this type of selection within PAw? Do I need to have python or java skills (or other) to create this type of widget or is it "just" a question of settings within PAw? Is it a type of visualization and I need to Update the Dimensions Category in the }DimensionAttributes Cube??
Year Selector Widget2.JPG (15.92 KiB) Viewed 2089 times
Year Selector Widget.JPG (10.73 KiB) Viewed 2089 times
Thank you in advance!
CTM1K
macsir
Version: PAL 2.0.9
Re: PAw range handle bars for Dimensions?
Post by macsir »
I think it is only available for Impact Diagram when you create score card type of cubes in TM1.
Also be aware that this functionality is not supported in the very latest release of PAW, where they have revamped the graphics and added the forecasting logic.
AFAIK no statements have been made on if this is a permanent or temporary situation.
(Untested, above is based on documentation...)
