We're using PAW version 47, creating books etc...
For some reason, after modifying a book / sheet on PAW (maybe too much ?) the zero suppression of some cube view just... don't work anymore even though the option is still on and worked before on the view.
Recreating the book with the same exact view and parameter makes it work, but after some time and modification the problem comes back again.
Does anyone got the same issue ? If yes... Do you have a solution ?
