I have a few questions re persistent feeders,
If the data changes in the cube do the persistent feeders get reprocessed, for example where there are conditional feeders?
If the rule is changed and then saved will the persistent feeders get saved (refired)?
I ask this because a rule change was made to a cube but the persistent feeders file still shows a date modified with an earlier date?
Also the rules are not behaving as expected!
Maren
Understanding Persistent Feeders
Re: Understanding Persistent Feeders
If you have conditional feeders, meaning an IF statement in there somewhere, then persistent feeders may not work properly for you without a rule save (to make the feeders recalculate).
