tm1 cpu memory at 97% and will not open architect
manu0521
OLAP Product: IBM TM1, Planning Analytics
Version: PA 2.0.5
Post by manu0521 »
Hi ,
I have a tm1 instance where the computer memory is at 97% , how do i trouble shoot which cube or feeders is causing the perfomance issues.
Re: tm1 cpu memory at 97% and will not open architect
manu0521 wrote: ↑Thu Sep 10, 2020 7:46 pm Hi ,
The first thing I'd do is look at the Windows Task Manager or equivalent and make sure that it's TM1 that is gobbling all of the memory and not some other process.
The second thing I'd do is right click on the server and select "Start Performance Monitor". Before you do that make sure that cube logging for any cubes which start with }Stats is turned OFF, or you'll end up with transaction logs the size of Mars. Then take a look through those cubes to see whether anything stands out.
