SubsetCreatebyMDX Union 3 elements or more
Markuss
Excel Version: 2010 + 2016
Post by Markuss »
Wonder if someone know how to union 3 elements (or more if needed) in given code? Works with two elements perfect. Does not work when added 3rd element.
Thanks in advance :)
SubsetCreatebyMDX( vSubset, '{UNION(
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( { [ ' | vDim1 | ' ].[ ' | vEl | ' ] }, ALL, RECURSIVE )}, 0)},
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( { [ ' | vDim1 | ' ].[ ' | vEl2 | ' ] }, ALL, RECURSIVE )}, 0)},
{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( { [ ' | vDim1 | ' ].[ ' | vEl3 | ' ] }, ALL, RECURSIVE )}, 0)} )');
Re: SubsetCreatebyMDX Union 3 elements or more
Union can only handle the joining of 2 statements. But you can nest Unions.
e.g.
{UNION(
	{Union (
And in the case you highlighted you could actually avoid a union altogether by using commas to first create a set of the 3 elements:
{[' | vDim1 | '].[' | vEl | '], [' | vDim1 | '].[' | vEl2 | '], [' | vDim1 | '].[' | vEl3 | '] }
You can then drill down into those:
{TM1FILTERBYLEVEL(
		{[' | vDim1 | '].[' | vEl | '], [' | vDim1 | '].[' | vEl2 | '], [' | vDim1 | '].[' | vEl3 | '] },
		ALL, RECURSIVE
	0
I would also recommend looking at the Expand function, it can make it a bit neater and more readable to construct statements in a TI that have a lot of variables.
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Post by ascheevel »
UNION is for joining 2 sets and 2 sets only AFAIK. You can nest a UNION though:
{UNION(
	{UNION({[set 1]}, {[set 2]})}
	,{[set 3]}
Markuss wrote: Tue Sep 01, 2020 2:44 pm Wonder if someone know how to union 3 elements (or more if needed) in given code? Works with two elements perfect. Does not work when added 3rd element.
The Union function can only merge 2 sets. But MDX also supports a union operator "+" which you can use as shorthand instead of {Union()}.
e.g.
{ {set A} + {set B} + {set C} }
